Using a Dynamic Alarm Threshold on Selected Rows
Solved1.44K views18th July 2023alarm templates
Jim Woodier [DevOps Member]765 27th October 2021 0 Comments
I'm considering using Dynamic Alarm Thresholds to monitor if certain routes of have been changed on an Evertz Magnum Router element. I've set the alarm type to discreet and started to set up baseline values. However, we only want to alarm on specific rows in the destination table, not all 2000 of them. Is there a way to set a discreet baseline value that will cause that row to be excluded from alarming? The image below shows the baseline editor before adding any baselines.
Also, what value should be put in the severity column in the alarm template... * ?
Pieter Van Compernolle [SLC] [DevOps Enabler]4.28K Posted 2nd November 2021 0 Comments
Hi Jim
I'm not sure if I understand your question well, but if you don't want to monitor on all the rows of your table you can specify a 'filter on the row key' or use conditions in the alarm template (see help).
