Upgrade Notice – RegisterDLLs did not exit within 60 seconds
Solved1.09K views27th September 2024upgrade
Catarina Grilo [SLC] [DevOps Enabler]3.62K 26th September 2024 0 Comments
Hi all,
After upgrading to 10.4.9, which appears to have completed successfully, I encountered the following notice:
‘RegisterDLLs.bat’ Process did not exit within 60 seconds
Upon reviewing the progress log, this message appeared during the following action:
step|Step 24/33: Register
Will re-register service SLASPConnection (Now x64; Previous path: “C:\Skyline DataMiner\Files\SLASPConnection.exe”)
Unregistered service ‘SLASPConnection’
Sleeping 5 seconds to allow unregister to complete
Registered service ‘SLASPConnection (x64)’
Unregistered server ‘SLProtocol’
Registered server ‘SLProtocol’ (x64)
Registered server ‘SLScripting’
Unregistered server ‘SLSNMPManager’
Registered server ‘SLSNMPManager’ (x64)
Registered server ‘SLPort’
DLL registration started
The system does not appear to be impacted in any noticeable way. However, what does this mean and how could it impact the system?
Catarina Grilo [SLC] [DevOps Enabler] Selected answer as best 27th September 2024
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K Posted 27th September 2024 0 Comments
Hi Catarina,
As mentioned in Actions that can be performed during an upgrade operation | DataMiner Docs, when you upgrade DataMiner usually removes all the services and the dlls in the older version so it can re-install them for the newer version you upgraded DataMiner to.
When it re-installs or re-registers them, the above .bat file is ran. Normally we expect the re-registering process to complete within a minute but the above notice simply says the process took more than a minute to register all the dll’s.
Normally, there isn’t any impact to the DMA due to this which is why it is a notice and not an error.
