Update Automation Script compiled as a Library
Solved1.41K views1st September 2023Automation script compile library
6
MAXIMILIANO FILHO [DevOps Member]996 12th April 2023 3 Comments
Hi
I created an automation script and compiled it as a library, but I needed to edit it and it seems that the changes were not compiled. It looks like the scripts that use this compiled automation are using the “previous version”. What can I do to solve this?
Thank you!
Julio Riambau [SLC] [DevOps Member] Posted new comment 1st September 2023
Toon Casteele [SLC] [DevOps Enabler] commented 12th April 2023
As long as your script validates it should rebuild automatically when you make adjustments. Did you verify that the script still validates?
MAXIMILIANO FILHO [DevOps Member] commented 12th April 2023
Yes, it’s still valid, I just changed one line.
This has already happened to me before, I will try to restart the DMA
Julio Riambau [SLC] [DevOps Member] commented 1st September 2023
I have the same situation.
Updated method on the compiled script and it does not seem to be updated in the scripts that are using it.
DataMiner (10.3.9.0-13293)
Is there another alternative other than restarting the DMA?
Thanks in advance.
Flavio Meneses [SLC] [DevOps Enabler]1.31K Posted 13th April 2023 1 Comment
Hi Maximilliano,
Most probably you need also to recompile the automation script that consumes such library (for that you can simply add a space or a comment and save it).
I believe this is not necessary in most recent versions of DataMiner, but in an older version, it might be necessary.
Kind regards,
MAXIMILIANO FILHO [DevOps Member] Selected answer as best 13th April 2023
MAXIMILIANO FILHO [DevOps Member] commented 13th April 2023
Hi Flavio,
I could solve it by restarting the DMA. Anyway, thanks for your tip!
Thank you!
