Unit tests invalid “nullable” values
Solved1.89K views24th January 2024
Yong Ting Lim [SLC] [DevOps Member]261 24th January 2024 0 Comments
Hi, I am currently having some issues building my unit tests.
This is my Qaction100 .csproj file with nullable enabled
However, if i were to disable nullable, I get other errors.
I’m not sure what is the fix for this, could someone help me out?
Yong Ting Lim [SLC] [DevOps Member] Selected answer as best 24th January 2024
Pedro Debevere [SLC] [DevOps Enabler]3.15K Posted 24th January 2024 1 Comment
In the project file, you’ll have to disable both nullable and implicit usings. QActions use C# 7.3 but these features are not supported in that language version. (the reason that these configurations are by default added when adding a test project is because it’s an SDK-style project.)
Yong Ting Lim [SLC] [DevOps Member] commented 24th January 2024
Hi Pedro, thanks! It’s working now.
