Unit testing for automation script
Solved1.39K views10th September 2025#automationscript MSTest Unit Test
Hari priya Venkatesan [DevOps Advocate]1.06K 28th March 2025 2 Comments
Hi Team,
I’m trying to write unit test case for automation script using MS test framework.
I’m unable to override the members provided by the Skyline.DataMiner.Utils.InteractiveAutomationScript to setup test cases.
There are members and method like this which unable to override or setup test data. Is there a way to resolve this
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 10th September 2025
Benjamin Hodžić [SLC] [DevOps Advocate]1.40K Posted 28th March 2025 0 Comments
Hello,
Perhaps you can try mocking the first-level property, TruckNameTextBox, and assign it a concrete value of the TextBox object instance.
It would look something like:
_mockDialog.Setup(d => d.TruckNameTextBox).Returns(new TextBox { Text = string.Empty”, …});
You tried to mock Text property within TruckNameTextBox, which initially wasn’t mocked, causing and exception
