Unit test Automation script – How to mock Element/Service Object?
Solved1.53K views9th December 2021automation scipt Unit Tests
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 9th December 2021 0 Comments
In an automation script you con do engine.FindElement() / engine.FindService() . This returns an element/Service object.
The method I want to test uses an IEngine input and relies on a engine.FindService, then I do a getpropertyvalue of a property of the service.
Based on those values I do an engine.Findelement. On that element I do a getparameter.
I’m unable to mock a service/element as it complaing of not having a default constructor. It only has an internal constructor.
Example of mock code:
Mock<Service> mockService = new Mock<Service>();
mockService.Setup(x => x.GetPropertyValue(“UserData”)).Returns(“test”);
However then the error returned is the following:
System.NotSupportedException: Parent does not have a default constructor. The default constructor must be explicitly defined.
The only way I can think of to get around this is by making wrappers for the different classes.
But that seems like a lot of overhead just to mock 4 methods.
engine.FindElement(“”)
element.GetParameter()
engine.FindServiceByKey(“”)
service.GetPropertyValue()
What would be the best way to mock/fake the above methods?
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 9th December 2021
Gellynck Jens [SLC]2.72K Posted 9th December 2021 2 Comments
Hi Tim,
A default constructor was added on the Element & Service types with release note 30003 (since 10.1.10.0), would it be an option to run your unit tests using the SLManagedAutomation.dll from a version higher than this?
Gellynck Jens [SLC] commented 9th December 2021
For completeness, the following types have default constructors since 10.1.10: Element, MailReportOptions, RedundancyGroup, ScriptDummy, ScriptMemory, ScriptParam, Service
Tim Vandenbruwaene [SLC] [DevOps Member] commented 9th December 2021
That has done the trick, referenced the newer dll in my test project and now it can use the mock.
Thanks
