UI Refresh Issue After Using disableWrite on Table Column
Solved1.19K views11th September 2025SLProtocol table
samita Acharya206 6th May 2025 0 Comments
I’m using the disableWrite to disable a column in a table if a toggle value is enabled. Functionally it works, but the UI doesn’t reflect the change immediately — the column only appears disabled after I click somewhere in the screen (like another cell or outside the table). The toggle value reflects immediately without any clicks
Is there a way to force the UI to refresh automatically so that the column’s disabled state is visually updated without requiring user interaction?
Pieter Van Compernolle [SLC] [DevOps Enabler]4.30K Posted 6th May 2025 2 Comments
Hi Samita,
I confirm the issue. I guess the feature was designed to work for rather ‘static’ rows. Nevertheless, this should be easy to support. Feel free to make that suggestion by creating a ticket in your m&s project.
PS: documentation mentions: It is not possible to change this value at runtime (options attribute | DataMiner Docs)
samita Acharya commented 7th May 2025
Hi Pieter, thank you for explaining this does not update automatically on runtime. Is there a way to force refresh a table in a qaction so the changes are reflected? or via automation script etc
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 8th May 2025
Nothing that is not impactful like readding the row for example. I tried with a simple 'value change', but that did not seem to trigger the update.
