Trigger automation script during GQI row selection
Solved2.16K views14th August 2024automation scipt GQI LCA
Hari priya Venkatesan [DevOps Advocate]1.06K 5th July 2024 0 Comments
I have a GQI which displays a table in LCA and during the selection of a any row in that table, an automation script should be triggered. Is it possible to trigger an automation script on that case or do we have any alternatives if not
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 14th August 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 5th July 2024 0 Comments
Hi Hari priya,
It is indeed possible to trigger a script when a row in the table is clicked, there are different options:
Use the double click event from the table
You can execute an action (for example, 'Launch a script') when a row in the table is double clicked.
Configure an action on click of a template block
Using this method you can execute a script on click of a table cell.
  1. Select table, go to 'Layout'
  2. Go to 'Column appearance' and select a column
  3. Select the 'Hyperlink' preset
  4. 'Customize preset' by clicking the 3 dots
  5. Within the template editor (see image) you can change the action that should happen when a click event occured
More info in this tutorial: https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Low_Code_Apps/Tutorials/Tutorial_Apps_Style_A_Table.html
Let me know if anything is unclear!
Hope this helps!
Best regards, Ward
Ward Haeck [SLC] [DevOps Advocate] Answered question 5th July 2024
