Trigger an Qaction through Automation
Solved1.87K views19th July 2024
Amer Hodzic [DevOps Member]784 25th June 2024 0 Comments
Hi Dojo Community,
I was wondering if it is possible to trigger a qaction through automation as I tried triggering the trigger but to no avail.
Amer Hodzic [DevOps Member] Selected answer as best 19th July 2024
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 26th June 2024 1 Comment
Hi Amer,
You could set parameter from automation which in turn will trigger QAction.
Hope this helps,
Cheers
Amer Hodzic [DevOps Member] Posted new comment 1st July 2024
Amer Hodzic [DevOps Member] commented 1st July 2024
The issue is that the Parameter is a context menu and when sending the dependencies as required it still fails
