Trending – Get trend values of a parameter in an Automation Script
Solved1.24K views16th February 2022Automation script trending
German Ballesteros [SLC] [DevOps Advocate]590 3rd February 2022 0 Comments
I need to get trend values of a parameter. I found a way to get it through DataMiner Web Service, using GetTrendDataForParameter method.
I would like to know if there is a better way to get that data from an Automation Script.
German Ballesteros [SLC] [DevOps Advocate] Selected answer as best 16th February 2022
Gelber Mahecha [SLC] [DevOps Enabler]1.97K Posted 3rd February 2022 0 Comments
Hi German,
You can use the GetAnalogTrendDataMessage to obtain trend data with a specified time range:
Disclaimer:
“Note that this is an internal call, and we do not recommend using this, as it is not officially supported, and we cannot guarantee that it will still work in the future. As a rule, you should avoid using SLNet calls, as these are subject to change without notice. We recommend using instead always the correct UI or automation options provided in DataMiner Automation or through our web API.”
