Timeout while discovering connection settings or endpoints
Solved5.35K views17th January 2025cube client datamine cube
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K 23rd August 2024 0 Comments
Hello,
We recently installed DataMiner using 10.2 installer but we are unable to access cube :
Connectionsettings :
* type=RemotingConnection;polling=0;zip=true
Endpoints:
http://192.168.1.10:8004/SLNetService
We have installed the URL Rewrite module, restarted IIS but the issue persists.
Cube logging indicates
Message : Login Failed.
Exception : (Code: 0x80040309) Skyline.DataMiner.Net.Exceptions.DataMinerException: Timeout while discovering connection settings or endpoints
at Skyline.DataMiner.Client.Framework.ClientConnection.MakeConnectionInternal(ConnectData data)
at Skyline.DataMiner.Client.Framework.ClientConnection.MakeConnection(Object state)
Https has not been configured in maintenancesettings. Is there anything else we could check to resolve this problem ? Thank you.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 17th January 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K Posted 17th January 2025 0 Comments
Unfortunately, the root cause was not found but a re-installation of DataMiner resolved the issue.
