The problem with the driver for DEV 1951 switch at switching control Mode
Solved772 views7th March 2024
Jaroslaw Burtny [DevOps Member]756 5th March 2024 0 Comments
Hi All.
We have a problem with the driver for DEV 1951 switch. The driver doesn't  has the option to set the remote communication mode and the device must work in Auto mode, but we also need to change this mode to remote. The current Skyline driver doesn't  do this remotely.
We can set these options remotely via SNMP SET as below to DEV switch :
How can I perform this procedure on DMA via script ?
Is there any support for SNMP tools on DMA system ?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th March 2024
João Severino [SLC] [DevOps Enabler]14.41K Posted 6th March 2024 0 Comments
It is possible that at the time of the development such control was not available or was not implemented resulting in that functionality being currently missing.
An option could be to reach out to your Skyline contact to extend the current connector to have the feature you are missing.
Until then you can use a tool like ManageEngine MIB Browser to manually poll and perform sets towards the device to validate and test what you need is possible on your device.
