template dataminer automation script solution not found
Solved1.10K views1st April 2025
Juan Falcon [DevOps Member]380 31st March 2025 0 Comments
Hello
Im trying to follow the video Kata #35: Interact with your DMS using an ad hoc data source – DataMiner Dojo but i have no the “dataminer automation script solution” only “dataminer automation script proyect” is the same or i have to install the template?
Thanks
Brecht Seys [SLC] [DevOps Enabler] Selected answer as best 1st April 2025
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 1st April 2025 0 Comments
Hi Juan
Since that Kata, the templates have had some major changes. For this Kata, you can use the ‘DataMiner Ad Hoc Data Source Project’ (which already holds the correct interfaces). The rest of the Kata should remain the same.
