System Design: one system, multiple local operations
Solved1.62K views31st January 2025
bruno santos [SLC] [DevOps Advocate]1.30K 15th October 2024 0 Comments
Hi, calling out system design and UEx experts. here's the case:
  • a single DMS monitors multiple local stations (between 30-100).
  • Each station has its own dedicated gear (10-20 devices/sensors)
  • Local operators should only see the equipment in their facility, as if it's a dedicated system
  • a central team manages all
  • must use html5
  • the UI should be the same for all stations, with just some variations on manufacturers or additional gear.
Would it be too cumbersome to maintain if we create a single app and repeat it for every station, with some having those variations?
bruno santos [SLC] [DevOps Advocate] Selected answer as best 31st January 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 16th October 2024 0 Comments
Hi Bruno,
I will rely on the permissions granted to operators/teams to define what information can be visualized in the dashboard/LCA. In that way, you can have a single UI that can focus on the presentation.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 16th October 2024
