System center options missing
Solved2.41K views17th July 2023database System Center
Bethany Sheppard20 31st March 2022 0 Comments
In my UI, system center shows only Overview, Search & Indexing, System settings, and Logging. How can I enable the other options e.g. Database?
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 1st April 2022 0 Comments
Hi Bethany,
You'll have to contact your system/IT admin for this.
Almost each module in system center has its own permission or set of permissions.
These must be granted to the Security group where you are member of.
Following image shows the difference between administrator (left) and operator with very strict activity (right)
Matthias Declerck [SLC] [DevOps Advocate] Answered question 1st April 2022
