switch between eventing and polling on specific cube
Solved1.92K views11th October 2023
Erik Severiens40 11th October 2023 0 Comments
In the training video (getting started) you can switch from eventing to polling to prevent the annoying wait time/firewall issue popup.
This feature (all settings) seems to have disappeared in cube settings.
How to alter this setting for a specific cube.
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 11th October 2023
Edith Lansens [SLC] [DevOps Member]791 Posted 11th October 2023 3 Comments
Information about these Cube settings can be found on the following page in the DataMiner documentation: DMA configuration related to client applications | DataMiner Docs
Edith Lansens [SLC] [DevOps Member] Posted new comment 13th October 2023
Erik Severiens commented 12th October 2023
Yes, same answer here. Also top! However there is also description of cube setting that is no longer there. Perhaps that chapter should be rewritten.
Edith Lansens [SLC] [DevOps Member] commented 12th October 2023
Hi Erik, I’ll take a closer look at the page and update it where necessary. Thank you for the feedback!
Edith Lansens [SLC] [DevOps Member] commented 13th October 2023
After reviewing the page, I’ve created and merged the following pull request: https://github.com/SkylineCommunications/dataminer-docs/pull/2117. However, only a minimal amount of information had become outdated.
It is possible that certain Cube settings may not be visible because you are using a recent DataMiner version. We currently provide support for DataMiner version 10.0.x and higher, so older settings might still appear in the documentation. Usually, the DataMiner version the information applies to will always be specified. For further details, please refer to the DataMiner support life cycle policy: https://docs.dataminer.services/user-guide/Reference/Software_support_life_cycles.html#dataminer-support-life-cycle-policy.
