Start script with correlation when 2 conditions (alarms) are not raised
Solved2.33K views7th September 2023Correlation correlation engine Correlation rules
Yvan Barbotin [DevOps Member]50 30th August 2023 0 Comments
Hi community,
I want to start a script when 2 alarms are not raised : NOT A and NOT B
I tried to use correlation with conditions as below
But when condition A or B are updated, the correlation is started and not only when all conditions are met.
How can I handle this use case.
Thanks
Amer Hodzic [DevOps Member] Answered question 30th August 2023
Yvan Barbotin [DevOps Member]50 Posted 7th September 2023 0 Comments
To solve this issue, I used script condition.
Example below.
