Start script with correlation when 2 conditions (alarms) are not raised
Solved2.30K views7th September 2023Correlation correlation engine Correlation rules
Yvan Barbotin [DevOps Member]50 30th August 2023 0 Comments
Hi community,
I want to start a script when 2 alarms are not raised : NOT A and NOT B
I tried to use correlation with conditions as below
But when condition A or B are updated, the correlation is started and not only when all conditions are met.
How can I handle this use case.
Thanks
Amer Hodzic [DevOps Member] Answered question 30th August 2023
Yvan Barbotin [DevOps Member]50 Posted 7th September 2023 0 Comments
To solve this issue, I used script condition.
Example below.
Amer Hodzic [DevOps Member]784 Posted 30th August 2023 0 Comments
Hi Yvan,
First the second Filter condition needs to be set to Not equal to.
I have tested what you are trying to achieve and it should work with the the two set Not equal to.
These will only trigger when an alarm is activated but that are not one of them.
Hope this helps.
