Start script using drag and drop
824 views17th December 2025Drag-and-drop Visio
Pedro Sánchez [DevOps Advocate]325 30th November 2025 0 Comments
Hi Dojo!
I'm having problems to initiate an script (it doesn't start at all) when using drag and drop and I'm passing an element to the target.
It's only ocurring when "NoConfirmation" option is set, if I didn't configure this option in Visio it starts normally with the confirmation box.
I also notice that script starts normally if no C# code is present in the automation script.
Shape1:
Element=2640/24
Shape2:
Execute=Script:ConnectApp|Unit_Destination=2640/25;Unit_Source=||||CloseWhenFinished,NoConfirmation
DropTarget=True
Automation script has c# code with:
using Skyline.DataMiner.Utils.InteractiveAutomationScript;
using System;
using System.Collections.Generic;
using System.Linq;
var SourceDummy = engine.GetDummy("Unit_Source");
Some help will be appreciated!
Thanks!
Klaas Dewitte [SLC] [DevOps Advocate] Answered question 17th December 2025
Klaas Dewitte [SLC] [DevOps Advocate]930 Posted 17th December 2025 0 Comments
It is currently not possible to launch an interactive automation script from drag and drop when using the NoConfirmation option on the execute shape data.
Patricia Pereira [SLC] [DevOps Member]124 Posted 9th December 2025 1 Comment
Hi Pedro,
It’s better if we create a ticket for this issue and investigate it properly. We’ll follow up with you via email to request more information.
Thank you!
Pedro Sánchez [DevOps Advocate] Posted new comment 9th December 2025
Pedro Sánchez [DevOps Advocate] commented 9th December 2025
Thanks Patricia! I just did it 1 hour ago 🙂
