STaaS: Indexing engine needed? (Misleading message in Cube?)
Solved462 views22nd October 2025Dataminer STaaS indexing indexing engine STaaS
Nils Hoven [DevOps Advocate]1.55K 22nd October 2025 0 Comments
after setting up STaaS, we still see the following message in the System Center in Cube:
Is this expected? To my understanding no further indexing engine is needed when using STaaS, so this message is slightly misleading...
Thanks!
Nils Hoven [DevOps Advocate] Selected answer as best 22nd October 2025
Julien Vermeulen [SLC] [DevOps Advocate]193 Posted 22nd October 2025 6 Comments
Hi Nils,
This is indeed expected after setting up STaaS because you no longer need to setup an indexing engine yourself.
Kind regards,
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 6th January 2026
Nils Hoven [DevOps Advocate] commented 22nd October 2025
Hi Julien,
thanks a lot, good to hear!
Maybe it's worth considering to enhance the message by inserting a reference to STaaS being operational…
Bert Vandenberghe [SLC] [DevOps Enabler] commented 22nd October 2025
Indeed, it looks like this should not be there when you are running on STaaS. I'll forward this to the correct people. Many thanks!
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 22nd October 2025
Meanwhile the correct people received the feedback and have a task to follow up on it. Wil keep you posted on the availability but for now, you can indeed safely ignore this configuration section. Thx for reporting!
(task reference: DCP282556)
Bert, Pieter, thanks a lot for your feedback, sounds great!
Nils Hoven [DevOps Advocate] commented 6th January 2026
Hi everyone,
I can see this is improved in 10.5 CU10 – thanks a lot!
Show 1 more comments
