STaaS: Difference between Database per Agent and Database per Cluster
Solved1.20K views27th August 2024database Dataminer STaaS DMS Configuration
Alex Barnett [DevOps Member]222 5th June 2024 0 Comments
Please is anyone able to confirm is there is any difference when configuring STaaS between the Type of Database connection parameter in System Centre.
Current you can select both "Database per Agent" and "Database per Cluster" options but is this essentially ignored when configuring STaaS or are there any differences in the way the STaaS is stored in Azure?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th August 2024
Guillaume Van den Berghe [SLC] [DevOps Member]230 Posted 6th June 2024 0 Comments
Hi Alex,
For STaaS there is no difference between "Database per Agent" and "Database per Cluster". All data from the cluster will be stored in the same way.
More information on how to setup your system with STaaS can be found in the docs: https://docs.dataminer.services/user-guide/Advanced_Functionality/Databases/STaaS/STaaS.html#setting-up-staas
With kind regards,
