[SRM] Resource element does not update its layout
Solved1.66K views18th January 2022SRM resources
Flavio Meneses [SLC] [DevOps Enabler]1.31K 18th January 2022 0 Comments
In our deployment we have updated the function definition that is in use by a resource (add/remove parameters). However, despite the resulted/generated xml being correct, the resource element does not display such changes in cube. We have already tried to recreate the resources and restart DataMiner, but without luck. As anyone already experienced the same issue, or have an idea of how to solve it?
Kind regards,
Flavio Meneses [SLC] [DevOps Enabler] Selected answer as best 18th January 2022
Ive Herreman [SLC] [DevOps Enabler]14.52K Posted 18th January 2022 1 Comment
Hi Flavio,
Have you tried to remove your cube cache?
This can be done easily from the cube launcher (through the cogwheel in the bottom right-hand corner).
Flavio Meneses [SLC] [DevOps Enabler] Posted new comment 18th January 2022
Flavio Meneses [SLC] [DevOps Enabler] commented 18th January 2022
Hi Ive,
Thank you for the suggestion. Unfortunately, it was not sufficient for our case.
