[SRM] Resource element does not update its layout
Solved2.07K views18th January 2022SRM resources
Flavio Meneses [SLC] [DevOps Enabler]1.35K 18th January 2022 0 Comments
In our deployment we have updated the function definition that is in use by a resource (add/remove parameters). However, despite the resulted/generated xml being correct, the resource element does not display such changes in cube. We have already tried to recreate the resources and restart DataMiner, but without luck. As anyone already experienced the same issue, or have an idea of how to solve it?
Kind regards,
Flavio Meneses [SLC] [DevOps Enabler] Selected answer as best 18th January 2022
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 18th January 2022 1 Comment
Hi Flavio,
I had something similar in the past. What worked for me was to change the connector version and function version.
Flavio Meneses [SLC] [DevOps Enabler] commented 18th January 2022
Hi Jens,
Thank you for the suggestion. This worked for our case!
