SRM – Is it possible to assign an alias to an integrated sub-view
Solved948 views16th December 2021SRM
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 16th November 2021 0 Comments
I can integrate my sub-views in my booking dashboard overview by specifying property HideInContainer with value false on my views.
Since my views have long names and it’s not that clean in the dashboard overview, is it possible to assign aliases?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 16th December 2021
Emmanuel Dal [SLC] [DevOps Member]4.63K Posted 16th November 2021 0 Comments
Jens,
This is today not supported.
You can either tweak your Visio drawing ( as I can see this is already a custom visio ) or make a request for a new feature
