SRM: How do you run an automation script when a booking starts?
Solved3.30K views20th May 2021Automation MDC service definition SRM
Cyrus Uible [SLC]50 20th May 2021 0 Comments
Use case:  We are using Process Automation to automatically deploy permanent bookings.  When the booking starts I want to run an automation that feeds in the ServiceID of the booking (or the ReservationID which I can use to get the ServiceID).  Tried using the "Created Booking Action" property on one of the nodes in the service definition, but this runs too early, as the booking\service isn't fully formed yet.  Is there another property I can use somewhere that will only run once the booking actually starts?
Cyrus Uible [SLC] Selected answer as best 20th May 2021
Maxim Bouckaert [SLC] [DevOps Member]179 Posted 20th May 2021 1 Comment
I think it should be possible by adding an action to START in the service definition:
If you already have a script attached to the start action, maybe you can call the script you want to run from the already running script?
Cyrus Uible [SLC] Unselected an answer 20th May 2021
Cyrus Uible [SLC] commented 20th May 2021
this is great thank you!
