SQL 2016 CU 17 for DataMiner SQL databases
Solved1.43K views19th July 2023
Jennifer Zhao 9th April 2021 0 Comments
We would like to know if it would be safe to install the SQL patch of SQL2016 CU17.
The KB number is 5001092
KB5001092 - Cumulative Update 17 for SQL Server 2016 SP2 (microsoft.com)
Thanks in advance.
Lucie Fiserova [SLC]110 Posted 9th April 2021 1 Comment
Hello Jennifer,
We are currently not aware of any issues with this, so you can go ahead with the install.
Have a nice weekend!
Jennifer Zhao commented 12th April 2021
Thank you Lucie for the confirmation.
