Specify which DMA will run an Automation Script in a DMS
Solved1.76K views26th July 2021Automation script
Jamie Stutz [SLC] [DevOps Member]1.18K 26th July 2021 0 Comments
Hi Dojo... in a DMS, is it possible to specific which DMA will execute an Automation Script? I know this is possible for Correlation Rules, but don't see the same options available for Automation Scripts. For context, but without getting into too much detail, we're using an Automation Script to trigger a process outside of DM, but need to be able to control which DMA this is happening on.
Thanks!
Jamie Stutz [SLC] [DevOps Member] Selected answer as best 26th July 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 26th July 2021 0 Comments
Hi Jamie,
Check the answer from this question:
How can I execute an automation script on multiple DMA
From within a script, you can launch a subscript and define the DMA where it needs to run
