Sort by and then sort by
250 views4th February 2026
Marco Virdis483 29th January 2026 0 Comments
Hello Dojo,
I would like to report an unusual behavior in a table: the values in one column are strings representing dates and times. When I try to sort the data alphabetically through the query, the first sort works correctly, but any subsequent sorts are only partially applied. Can someone explain why this happens? What am I doing wrong? Thank you
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 4th February 2026
Wout Mahieu [SLC] [DevOps Catalyst]11.61K Posted 4th February 2026 0 Comments
Hi Marco,
Do you have some more information about the query you are using when encountering this? Knowing the types of the columns you are sorting on could give some clues.
