SNMP trap forwarding – Keep source string in custom bindings
Solved2.01K views18th July 2023
Max Stephany211 2nd November 2021 0 Comments
Hello,
Is it possible to always have the source OID transmit the same string in an SNMP forwarding configuration?
For example, the Source string normally is "Dataminer System" but when a correlation rule is triggered, the string reads "Correlation Engine" instead. It is logical, but in some scenarios the traps may be, for example, forwarded to a NOC which in return notifies about an alarm coming from "Correlation Engine", and it would be more difficult to determine where the alarm originates from.
In our case it is not yet essential, but it could simplify things later on.
Thanks!
Regards,
Max
Max Stephany211 Posted 5th November 2021 0 Comments
Hello Jeroen,
That is indeed a nice workaround, thank you for your input!
Regards,
Max
Max Stephany Answered question 5th November 2021
