Smart Serial receiving UTF-8 encoded messages
Solved1.84K views22nd September 2022
Julio Riambau [SLC] [DevOps Member]302 23rd March 2022 0 Comments
A driver is using a Smart Serial connection to act as a server.
Some of the received messages will display incorrectly some UTF characters.
Example message: "CreatePathRequest Athletes Unlimited Volleyball – (480) 491-0389"
Displayed message: "CreatePathRequest Athletes Unlimited Volleyball – (480) 491-0389"
The parameter used to receive the message uses RawType other which allows ASCII characters.
Would there be a way to process this kind of message?
Thanks in advance.
Best regards,
Julio Riambau [SLC] [DevOps Member] Selected answer as best 22nd September 2022
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 24th March 2022 0 Comments
Hi Julio,
Does your protocol have the unicode option in the Protocol/Type@options attribute?
If not, adding that will probably be your solution.
However, note that adding it will be a breaking change so you'll have to create a new driver range.
Also, refer to the documentation as you will probably then also need to use the Command@ascii attribute if you do send commands.
Unicode option: options attribute | DataMiner Docs
ascii option: ascii attribute | DataMiner Docs
