Smart serial listener – replying to a single client not possible sans “after response” trigger?
Solved2.69K views27th August 2024client command listener server smart-serial
Alex Johnson [SLC] [DevOps Advocate]921 4th June 2024 3 Comments
Hi all,
In DataMiner Docs, we have a way to configure smart serial listener to reply to a single client:
However, this is only "after response". I have an implementation where I need to use one connection to send a command back to the client after a button press, e.g not after response. As it currently is working, whenever I send the command it broadcasts it to all available/open clients. Is there a way around this?
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 27th August 2024
Michael Wells [SLC] [DevOps Member] commented 4th June 2024
More information: what we need to do is somehow keep track of the TCP session source IP port from which a client sends a specific message, store it in a parameter on a row associated with that message, and then use that TCP source IP port value to become the TCP destination IP port to which we send a response message based on how and when an operator chooses to process a given message through various buttons linked to QA’s.
We know we can use SmartIPHeader to get the IP, Port and Sequence Number and could store that in the response, but can we somehow use this option in the construction of a new message (not an automatic response to the inbound message) to force SLPort to utilize a specific (dynamic based on the incoming message) TCP Destination IP Port to send the message to the device?
Jeroen Neyt [SLC] [DevOps Advocate] commented 5th June 2024
Would you happen to know the IP addresses of the clients upfront or is that unknown?
Michael Wells [SLC] [DevOps Member] commented 5th June 2024
IP Address is known.
Alex Johnson [SLC] [DevOps Advocate]921 Posted 27th August 2024 0 Comments
Conclusion - we ended up omitting the smart serial set flow favor of an SCP client for sets.
