Smart serial listener – replying to a single client not possible sans “after response” trigger?
Solved2.85K views27th August 2024client command listener server smart-serial
Alex Johnson [SLC] [DevOps Advocate]921 4th June 2024 3 Comments
Hi all,
In DataMiner Docs, we have a way to configure smart serial listener to reply to a single client:
However, this is only "after response". I have an implementation where I need to use one connection to send a command back to the client after a button press, e.g not after response. As it currently is working, whenever I send the command it broadcasts it to all available/open clients. Is there a way around this?
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 27th August 2024
Michael Wells [SLC] [DevOps Member] commented 4th June 2024
More information: what we need to do is somehow keep track of the TCP session source IP port from which a client sends a specific message, store it in a parameter on a row associated with that message, and then use that TCP source IP port value to become the TCP destination IP port to which we send a response message based on how and when an operator chooses to process a given message through various buttons linked to QA’s.
We know we can use SmartIPHeader to get the IP, Port and Sequence Number and could store that in the response, but can we somehow use this option in the construction of a new message (not an automatic response to the inbound message) to force SLPort to utilize a specific (dynamic based on the incoming message) TCP Destination IP Port to send the message to the device?
Jeroen Neyt [SLC] [DevOps Advocate] commented 5th June 2024
Would you happen to know the IP addresses of the clients upfront or is that unknown?
Michael Wells [SLC] [DevOps Member] commented 5th June 2024
IP Address is known.
Jeroen Neyt [SLC] [DevOps Advocate]2.61K Posted 6th June 2024 0 Comments
If the connector has only a smart-serial connection and you know the IP addresses of the clients upfront, it might be an option to configure an element per client.
The actual listening socket is still shared over the multiple element instances but each element context has its own dedicated connection to one specific client.
This can be achieved by configuring the Accepted IP address field of the smart-serial connection.
This would be an example configuration for the connection to the client located at 179.226.97.50. You would then need to do this for all clients.
Admittedly this is a bit of a configuration overhead but today I see no other way in how to target a specific client on request.
If this configuration is not an option, I would recommend you to submit a feature suggestion to try to come up with a solution on how this could be covered from within a connector.
Jeroen Neyt [SLC] [DevOps Advocate] Answered question 6th June 2024
