Smart Serial Listener not sending out commands
Solved2.27K views16th May 2024command listener makeCommandByProtocol server smart-serial
Alex Johnson [SLC] [DevOps Advocate]921 14th May 2024 0 Comments
Hi all,
I'm working on a smart serial protocol that will act as a "listener" (ip, any, one response with a param of length next param that is parsed as messages come through). I am trying to send a command, and it's showing up in the streamviewer, but I can NOT find it in wireshark, despite other traffic (ie messages from device) coming through. Needless to say, the set is not going through on the device.
My setup: makeCommandByProtocol, primary connection of type smart-serial, ip any, port 20002. Secondary connection of type smart-serial, ip <specificDeviceIP>, port also 20002.
I have my Pair with one command and no response where the command is one param that is set via qaction, and I can see the correct command in the streamviewer. I have my generic response that is parsing incoming traffic correctly, and also displaying "no response needed" when I try to send the command.
Pair setup in xml:
Streamviewer example:
I get a "No response needed" response from Streamviewer, but I see nothing in a wireshark, despite seeing the correct traffic coming through for the listening/parsing of messages.
Any ideas on what could be going wrong/other things I should check? I've tried almost everything I can think of including creating a bare bones driver that only sends the command and doesn't listen.
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 16th May 2024
Thomas Warnez [SLC] [DevOps Advocate]791 Posted 16th May 2024 0 Comments
Hi Alex,
Do I understand you want to sent data via the secondary connection?
  1. Did you already checked that the group is having the option to send it via the secondary connection
<Groups>
         <Group id="" connection="0" />
         <Group id="" connection="1" />
</Groups>
2. I feel it is a bit related to a bug in the past.
Smart-serial (2nd) connection seemingly not working (from 10.2.7)
There is a common mistake made in the driver definition that is now popping up extra by SW improvements from 10.2.7 => the reason it used to work is the bug.
Expected behavior:smart serial connection(s) will take all the defined header and/or trailer params into account. effect: data packages using a different header / trailer will not be passed => not even shown in the streamviewersolution: only define the header / trailer params you need ( = clean up params properly when removing responses)
Note that this is a well known behavior when using smart-serial as main connection, but we might miss it when using smart-serial as 2nd connection. In order to use headers and/or trailers in the main connection and disregard them in the 2nd, we need to define the connection in those params. <Type options="headerTrailerLink=1;connection=0">trailer</Type>
https://docs.dataminer.services/develop/devguide/Connector/ConnectionsSmartSerialDataForwarding.html#headers-and-trailers
Data forwarding | DataMiner Docs
Thomas Warnez [SLC] [DevOps Advocate] Answered question 16th May 2024
