SLAlerter – Sound only?
Solved2.20K views12th October 2022SLAlerter
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 12th October 2022 0 Comments
Can the SLAlerter tool be configured in such a way that only a sound notification is triggered, but no balloon popup, in case alarms occur that match the configured filter(s)?
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 12th October 2022
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 12th October 2022 0 Comments
There might be a workaround.
I experienced that when you drag the popup balloon to a screen that is later removed, the popup balloons appear on that location still even when the screen is no longer attached.
So the workaround involves attaching and detaching another screen, which is not ideal :-), but maybe it can be a temporary solution while you wait for software changes.
If you go for this workaround I also advise to set the auto-hide feature suggested by Matthias.
