Show a popup/toast inside a Cube View from a correlation-triggered Automation?
Solved857 views12th September 2025#automationScipt Correlation popup page view
Daniel Silva [DevOps Advocate]262 10th September 2025 0 Comments
I have an Automation Script triggered by a correlation on a critical alarm. After it runs headless, I want operators to see a visual notice inside a DataMiner Cube View .
I tried a simple popup:
var ui = new UIBuilder { Title = "Info", RequireResponse = false };
ui.AppendBlock(new UIBlockDefinition { Type = UIBlockType.StaticText, Text = "Switch executed." });
engine.ShowUI(ui);
But when launched by correlation it fails with:
Error launching script: interaction is required to execute this script
Question: Is there a supported way to display a popup/toast/banner directly in a Cube View when the script is triggered by correlation? If yes, how can this be done?
Daniel Silva [DevOps Advocate] Selected answer as best 12th September 2025
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.75K Posted 11th September 2025 1 Comment
Hi Daniel,
If you would like to show a pop-up and let the user interact with it, the approach with an interactive script and the 'FindInteractiveClient' that Ive suggests would be the way to go.
If you however would just like to show a pop-up message, you can use the 'BroadCastPopupRequestMessage' SLNet message. With this, you can have a popup-up that can be configured with a title, message and recipients (empty if it should pop up for everyone). More info can be found here: https://docs.dataminer.services/release-notes/General/General_Main_Release_10.0/General_Main_Release_10.0.0_new_features_2.html#all-cube-clients-will-now-display-broadcast-popups-sent-from-qactions-automation-scripts-etc-id-21733id-21928id-22089
Daniel Silva [DevOps Advocate] Posted new comment 12th September 2025
Daniel Silva [DevOps Advocate] commented 12th September 2025
Thanks, Thomas — that was exactly the idea, and the popup worked perfectly. Appreciate the help!
