Shifting spectrum trace
Solved1.47K views12th April 2023spectrum
7
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 6th April 2023 0 Comments
When a spectrum measurement point is created, we have the option to offset the frequency (shift the spectrum trace). This is typically done for conversion between L-Band and C/Ku Band.
Can we somehow achieve the same for an analyzer element where no measurement points are defined or selected? Of course we prefer not to make driver modifications.
I assume creating a dummy measurement point could be a option, but even better if we can do completely without.
Ruben Vandepitte [SLC] [DevOps Advocate] Selected answer as best 12th April 2023
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 6th April 2023 0 Comments
To my knowledge that is not possible as a standard function, this is only available indeed on a measurement point, or alternatively indeed if you would intervene on a driver level.
