Shape with one element property and tooltip for another element
Solved848 views6th February 2023
Yvan Barbotin [DevOps Member]30 25th January 2022 0 Comments
Hello,
I have a shape with a parameter of an element to give a status. And on this shape I need to add in a tooltip/popup a property of another element.
To support this customer demand I create a first shape for the status and put on top a second transparent shape for the tooltip.
Do you have a better solution for this case?
Thank you
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 25th January 2022
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 25th January 2022 0 Comments
Hi Yvan, probably you can use the "Tooltip" shape data and include a placeholder referring to the property of the other element. See help for more information.
