Setting Parameter Description not working
Solved1.09K views18th May 2026Parameter Description SetParameterDescription
Robert Thevis [DevOps Advocate]310 18th May 2026 0 Comments
Hello everyone,
I have a Connector where I need to dynamically set the Parameter Description of a number of Parameters. Basically the Parameter Descriptions need to include the Site Name.
I am doint this using a QAction and SetParameterDescription. This works fine on newly created Elements, but now I have updated the Connector and added some Parameters. I expected to be able to change the Parameter Description of the new Parameters the same way, but nothing happens.
I tried:
  • Setting the Parameter Description in the QAction
  • Changing it directly in the Description.xml File
  • Restarted Cube and the Element multiple times
  • Restarted the entire DMA
Nothing helps, the new Parameters simply refuse to be renamed. What am I missing to be able to rename Parameters in these "older" Elements?
Best Regards,
Robert
Robert Thevis [DevOps Advocate] Selected answer as best 18th May 2026
José Silva [SLC] [DevOps Enabler]2.19K Posted 18th May 2026 1 Comment
Hi Robert,
Here is the suggestion I was referring to:
Robert Thevis [DevOps Advocate] Posted new comment 18th May 2026
Robert Thevis [DevOps Advocate] commented 18th May 2026
Hello José,
that was the solution. It worked using this.
The Protocol versions are the same (both Production).
Anyway, it is solved now.
Thank you!
Best Regards,
Robert
