Setting data to parameters in DataMiner
Solved2.43K views10th August 2021parameter Parameters
ryan yahia900 9th August 2021 0 Comments
Is there a maximum length/ no. of bytes that can be set to a parameter. I have a parameter that holds a large body of text and it doesn't seem to be holding the full text that is being polled, and wondering if it is a case of it exceeding the number of bytes that a parameter can hold.
Thank you.
ryan yahia Selected answer as best 10th August 2021
Jens Vandewalle [SLC] [DevOps Advocate]10.01K Posted 9th August 2021 1 Comment
Hi Ryan,
Are you using the lines attribute in the Measurement - Type tag?
This will show a multiline box
ryan yahia Edited comment 9th August 2021
ryan yahia commented 9th August 2021
Hi Jens,
I’ve attached the parameter in question. The parameter is set by a connection to an endpoint with a GET request and the response content is set to the parameter shown below. When I enter the url into a browser and compare it to what I receive in the stream viewer and what gets set to the parameter – the parameter value seems to not be the full content compared to what I see in the stream viewer and browser.
The Measurement – Type tag in my parameter is:
string
