Set static background color for a shape
Solved1.83K views20th October 2022background button shape static
Daniel Zank [DevOps Advocate]299 20th October 2022 0 Comments
Hi community!
I tried to set a static background color for two shapes used as a “button”, as it is shown in the following picture – Stopp = red and Start = green:
One of the Shape-Data:
But the output in dataminer (version 10.2.0.0) is as attached:
May someone can help me with the problem, to increase the user experience?
Best regards and thank you!
Daniel Steinbrecher
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 20th October 2022
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 20th October 2022 1 Comment
Hi Daniel,
Can you try by removing the Control=Button option.
Daniel Steinbrecher commented 20th October 2022
Hi Jens,
thanks for your fast answer, it works fine!
Best regards, Daniel
