Set more than one parameter for the same element
Solved1.54K views18th April 2025set command
Beatriz Rios [DevOps Member]34 7th October 2024 3 Comments
Hello everyone! I would like to update two different parameters for the same element in a single action. Is it possible to use the "set command" to update both parameters without using a script?
Beatriz Rios [DevOps Member] commented 7th October 2024
In this case, I reffer to an action in a View
Marieke Goethals [SLC] [DevOps Catalyst] commented 31st January 2025
Nils Hoven [DevOps Advocate]1.82K Posted 8th October 2024 0 Comments
Hi Beatriz,
AFAIK, no:
Visual Overview Execute Set on multiple parameters - DataMiner Dojo
BR
Nils
