serializing / deserializing dom instance
Solved1.58K views3rd July 2024DOM
Tim Vandenbruwaene [SLC] [DevOps Member]2.28K 2nd July 2024 0 Comments
What's the best way to serialize and deserialize a dom instance?
Would like to get a filtered set of dom instances moved from one DMS to the other.
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 3rd July 2024
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 3rd July 2024 2 Comments
Hi Tim,
The easiest way to serialize and deserialize a DOM instance is by using the 'domInstance.ToJson()' and 'DomInstance.FromJson()' methods.
Thomas Ghysbrecht [SLC] [DevOps Enabler] Posted new comment 3rd July 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 3rd July 2024
The ToJson and FromJson methods can indeed be used to serialize and deserialize a single instance, but what’s the preferred way to serialize a collection of instances?
Thomas Ghysbrecht [SLC] [DevOps Enabler] commented 3rd July 2024
The simplest would be to just loop over your collection and use the same methods. It should also be possible to use Newtonsoft.Json and serialized/deserialize a ‘List’, this way you have one large JSON.
