Serial Simulator – streaming data over serial port
Solved2.00K views27th June 2022serial simulator
Bing Herng Chong [SLC] [DevOps Advocate]1.74K 26th November 2021 0 Comments
Hi all, I am aware of a QA simulator to simulate SNMP and HTTP devices and also a Skyline Serial Simulator driver capable of simulating request/response type interaction.
Is there a serial simulator (driver/tool) that exists to help simulate/test the following type of device:
  1. The device is a terminal server (Moxa). It connects to an end device (NMS) over a serial connection (printer port). The end device will stream data over this serial connection. The terminal server will then convey this data over TCP/IP to DMA.
  2. The DMA driver will connect to the terminal server over TCP/IP. The driver simply listens for incoming data. It does not need to send any requests/commands.
  3. The terminal server keeps the TCP/IP connection alive using TCP-keepalive packets.
Any sort of info/help would be much appreciated on how such a driver can be validated without access to the actual device.
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 27th June 2022
Simon Raine [SLC] [DevOps Member]2.08K Posted 23rd December 2021 0 Comments
I believe this is not currently covered with the existing simulation driver.
We’re looking to move all simulation to one tool upcoming in the new year, and this would be a case we could look to include. It doesn’t seem to be a difficult thing to cover.
I will contact you accordingly to look at the requirements.
