Serial – Fixed Length Responses Are Waiting For Timeout
Solved1.67K views7th July 2023Response serial serial protocol
8
Thomas Remmery [SLC] [DevOps Advocate]1.06K 1st March 2023 0 Comments
I’m noticing some unexpected behaviour when polling a device using a serial connection. All of the responses for my protocol have a fixed length. DIS does not indicate any issues regarding responses waiting for timeout. No headers or trailers are defined. The device does not go into timeout, but from the StreamViewer I can see that the response is only registered after the configured timeout time.
An example for polling the location of the device:
Command:
Response:
StreamViewer (configured timeout time is 3 seconds):
My DataMiner version is 10.2.0.0-12184-CU6.
Am I missing anything?
Thanks in advance.
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K Posted 1st March 2023 0 Comments
Hi Thomas,
Could it be that you are getting the wrong data from the device?  Looking at the streamViewer data and your response I would translate it to this:
03      Protocol version
07      Message type
00 11 Message idPoll location
81      Reply
00      Reserved
00      Length
40      Data
Could you also check in the device documentation how long the Response Length is perhaps it should have a fixed length of 2?
