Serial connector for USB device
Solved2.63K views15th June 2021Connector serial
Robbie Demaegdt [SLC] [DevOps Member]666 10th June 2021 0 Comments
Is it possible to create a serial connector that will interface with a device connected by USB to the dataminer server?
Robbie Demaegdt [SLC] [DevOps Member] Selected answer as best 15th June 2021
Jeroen Geldhof [SLC] [DevOps Enabler]5.52K Posted 14th June 2021 1 Comment
Some devices use a USB to serial adapter internally.  In that case the connected PC indeed adds a COM port for that adapter.  So if the device is directly connected to a DMA server, DataMiner will be able to communicate with that device.
If however the USB device does not have a serial adapter it will not be possible to communicate with that device directly.
In that case a layer in between is needed, some bridging code is needed.
On one side you'll have code to communicate with the device over the correct drivers, and on the other side you can expose an API that DataMiner can reach.
Preferably the manufacturer makes that available to us of course so that DataMiner can connect to an API on a server that has that device connected to it.
Robbie Demaegdt [SLC] [DevOps Member] commented 15th June 2021
It’s indeed a USB device and sadly enough there is no decent documentation or API to use from the manufacturer. There are some 3th party APIs available from reverse engineering the communication
