Serial connector for USB device
Solved2.36K views15th June 2021Connector serial
Robbie Demaegdt [SLC] [DevOps Member]666 10th June 2021 0 Comments
Is it possible to create a serial connector that will interface with a device connected by USB to the dataminer server?
Robbie Demaegdt [SLC] [DevOps Member] Selected answer as best 15th June 2021
Jeroen Geldhof [SLC] [DevOps Enabler]5.50K Posted 14th June 2021 1 Comment
Some devices use a USB to serial adapter internally.  In that case the connected PC indeed adds a COM port for that adapter.  So if the device is directly connected to a DMA server, DataMiner will be able to communicate with that device.
If however the USB device does not have a serial adapter it will not be possible to communicate with that device directly.
In that case a layer in between is needed, some bridging code is needed.
On one side you’ll have code to communicate with the device over the correct drivers, and on the other side you can expose an API that DataMiner can reach.
Preferably the manufacturer makes that available to us of course so that DataMiner can connect to an API on a server that has that device connected to it.
Robbie Demaegdt [SLC] [DevOps Member] commented 15th June 2021
It’s indeed a USB device and sadly enough there is no decent documentation or API to use from the manufacturer. There are some 3th party APIs available from reverse engineering the communication
Leander Druwel [SLC] [DevOps Member]2.04K Posted 10th June 2021 2 Comments
Hi Robbie,
Not sure about this, but I believe a USB gets mapped to a COM number on the server when plugged in. That is also visible in the Device Manager when plugging in the USB.
The COM is then also available as Serial port into the wizard. I did not test if communication works through this though.
Leander Druwel [SLC] [DevOps Member] Posted new comment 11th June 2021
Robbie Demaegdt [SLC] [DevOps Member] commented 10th June 2021
Yeah I know about the COM port but I have no idea if the bus address has to be filled in.
The other settings can be found in the device manager but I don’t get any responses.
Currently my bus address is empty because I can’t fill in a string value (COM3).
Leander Druwel [SLC] [DevOps Member] commented 11th June 2021
Ok, guess that you’re quite close then. To me, using a bus address would not really make sense, as you’d only expect a single unit on the serial connection. Others can surely jump in here if we would have used that in the other connectors.
