Separate websites using different certs on DataMiner
Solved1.78K views18th August 2023HTTPS
Philip Argent [DevOps Advocate]1.07K 17th August 2023 0 Comments
Would it be possible to have two websites in IIS for DataMiner with different certs on each for https connections?
Michiel Saelen [SLC] [DevOps Advocate] Answered question 18th August 2023
Michiel Saelen [SLC] [DevOps Advocate]6.35K Posted 18th August 2023 1 Comment
Hi Philip,
There are probably multiple ways, but an easy way would be to have two DNS records (e.g. ‘first.mydomain.com’ and ‘second.mydomain.com’) pointing to both the same IP. In IIS on the DMA, you could then configure the bindings as below.
Philip Argent commented 18th August 2023
Thank Michiel,
Of course you can, I was completely forgetting that fundamental part of web servers.
