Sending “I’m going to stopped’ message to other element
Solved2.38K views17th September 2021driver inter element communication
Maxim Bouckaert [SLC] [DevOps Member]179 17th September 2021 0 Comments
Hey everyone
For a manager/node driver we want to do the following.
If the node is set to a stopped state, we want to inform the manager as soon as possible.
As of now, we do this by doing a check every x time from within the manager, but because there can be a lot of nodes running, we don't do this a lot, giving a considerable delay.
Is there a way to have this node declare to the manager that it is going to a stopped state (a last trigger/another way to inform the manager)? Or is pinging the element from within the manager element the only way?
Wannes Wittevrongel [SLC] [DevOps Member] Answered question 17th September 2021
Wannes Wittevrongel [SLC] [DevOps Member]169 Posted 17th September 2021 0 Comments
I think you can achieve this by subscribing to the element state of those nodes.
https://help.dataminer.services/development/DataMinerDevelopmentLibrary_Customer/part4ClassLibrary/CLASkylineDataMinerLibraryProtocolSubscriptionMonitors/ElementMonitorExtensions_methods.htm?rhhlterm=ElementMonitorExtensions&rhsyns=%20
