Script to delete element
Solved2.64K views8th February 2023automation scipt delete element
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 7th February 2023 0 Comments
I want to create a script that deletes an element based on the DMA/EID input parameter.
Doing a follow I found that this uses the SetElementStateMessage.
I also want to check the response to see if it succeeds, which should be a SetEelementStateResponseMessage.
However in C# it doesn\'t seem to find that class.
What\'s the propper way to check the response from the SetElementStateMessage in an automation script?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 8th February 2023
Tom Van Bruaene [SLC] [DevOps Member]913 Posted 7th February 2023 1 Comment
Is it possible you're trying this on an older Dataminer version?
SetElementStateResponseMessage was added in 10.0.5, so in versions prior to this, we don't respond with anything to the SetElementStateMessage.
Jeroen Geldhof [SLC] [DevOps Enabler] Posted new comment 8th February 2023
Jeroen Geldhof [SLC] [DevOps Enabler] commented 8th February 2023
It’s a 10.2.12. But I eventually went for the solution with the IDms package suggested below.
