Script running for too long
Solved1.13K views4th November 2024
Stefan Schedletzky [DevOps Advocate]2.76K 4th November 2024 0 Comments
I have a script which is checking every Cisco Switch if it’s using DWDM SFP’s. As we have over 200 switches, this takes a while. But I get the following error, so my question is how can I increase the timeout time?
Stefan Schedletzky [DevOps Advocate] Selected answer as best 4th November 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 4th November 2024 1 Comment
Hi Stefan,
You could update the timeout of the script. See the following question:
Script timing out
Hope it helps.
Stefan Schedletzky [DevOps Advocate] Posted new comment 4th November 2024
Stefan Schedletzky [DevOps Advocate] commented 4th November 2024
Hi Miguel,
indeed it’s helping. For all people maybe having the same issue:
engine.Timeout = TimeSpan.FromMinutes(10);
